Importing Classes
Well I typically just copy and paste an object that has the class assigned to it but that means opening the file, finding the objects, etc. Obtuse. I do have atemplate with all the classes, but inevitably I create new ones that don't get into the template. There MUST be a way to import the class without having to go get the object.
There was a thread recently about referencing classes from one file (eg a library) to another file. DWorks excellent PIO for this is linked near the end.
First the thread:
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=150716&Searchpage=1&Main=30640&Words=import+class&Search=true#Post150716
Then DWorks Link:
http://www.dworks.be/English/Products/Commands/DListClasses.html
-B
there is the reference method for classes you want linked to another file but there is also another way that imports just the class definition for when you don't want the class referenced.
open the create new class dialogue
click the 'import...'
navigate to the file were the class you want is located
select the class
import it, done.
