Print All Symbols Command
If you are using VW 9, there is a folder called Object Library Catalog. [ VW9.x>Extras>Object Library Catalog ]When you open the Object Library Catalog folder you will see a listing of .pdf files named the same as the coordinating .mcd file in which the symbol resides. Each pdf file will have a small image of the symbol, the automatic class assignment value, symbol name, and the attached class if any. You can then print out the pdf files.
If you are using VW 8 on MAC, the location is the same. If you are using VW 8 on a PC, this catalog is not included for some odd reason. I can email the catalog to you if this is your case.
Of course this catalog will only list the symbols that are in our symbol library. To get a print out of symbols you have created, you will have to insert the symbols in a drawing one by one and then print that drawing out.
[ 02-13-2002: Message edited by: Katie ]
