JSiegel Posted January 16, 2011 Share Posted January 16, 2011 I was just setting my wall heights to cut a section and realize the Delta-Z is out of whack & I can't seem to alter it. See the attached screen shot. Where is my mistake.? TY J Quote Link to comment
michaelk Posted January 16, 2011 Share Posted January 16, 2011 What happens when you double click on a layer? Quote Link to comment
JSiegel Posted January 16, 2011 Author Share Posted January 16, 2011 When I double click the layer through the Tools>Organization the Z & DZ just confirms the settings/heights I have input? Each wall when I select it shows up with a strange DZ in the OIP. For instance my 2nd floor walls in the OIP are DZ-4" , Z=11'-0" which relates to ... nothing I have input? Quote Link to comment
bcd Posted January 16, 2011 Share Posted January 16, 2011 I think it's confused by the 12' 1/2" z value and is reading it somewhere as 12.5", 12'1/2"-12.5"=11', I don't know where the error is but perhaps if you re-set all you z and delta Z values to 0 and then back again you might get the software to reset the values correctly. Quote Link to comment
JSiegel Posted January 16, 2011 Author Share Posted January 16, 2011 bcd, you are correct the 12' 1/2" was confusing the program. I reset all levels to zero, closed VW and reset the levels(leaving out the 1/2") and all is well. TY J Quote Link to comment
CipesDesign Posted January 16, 2011 Share Posted January 16, 2011 Hi Jeremy, if your file is small enough could you attache here? Or try this: you should be able to edit the z and delta z of a design layer via the layer setup dialog (double click on each layer and change values as needed). Then select all of your walls (in each layer) and make sure they are at bottom z = 0.... Sometimes I find that erroneous values can end up in the OIP when I try (but fail) to exit the OIP and return to the drawing. I often use the number keys to set 3d views, or return to top/plan and if I unintentionally still in the OIP when I hit the numbers some odd things can result... Quote Link to comment
JSiegel Posted January 16, 2011 Author Share Posted January 16, 2011 Hi Peter, I will post the file later. I think I spoke to soon, the layer heights are OK but my windows are set at a height in the OIP of -11'-0"???, yet its a 5'-4" window set at 7'-6" head (see attached) TY J Quote Link to comment
JSiegel Posted January 16, 2011 Author Share Posted January 16, 2011 This is the screen shot that should have accompanied the prior post. Quote Link to comment
CipesDesign Posted January 16, 2011 Share Posted January 16, 2011 Jeremy, for some reason, whenever a wall is moved up or down after windows or doors have been inserted the windows and doors stay put, but their "height" in the OIP changes. VW's has behaved like this for as long as I can remember (it's almost never a desired behavior). The only solution is to change the "height" field of the windows or doors back to 0. In your case it looks as if you might have moved the walls 11ft up? In any case, changing the values back to 0 ought to solve it. Quote Link to comment
JSiegel Posted January 16, 2011 Author Share Posted January 16, 2011 Peter, that is exactly what I had done, copied the walls up to the next level. Not something I typically do so thanks for your input, now I know. TY J Quote Link to comment
