Nurbs
Heath
You can't.
Iges is supposed to be standardized, but I have had different results importing from different sources. Also separating objects can sometimes be a problem after import.
If you have other 3D programs than VW, maybe you can try one of them as a translator.
If not ask the source to change settings and export again. When it works, it is quite wonderful compared to DXF/DWG.
