Christiaan Posted January 11, 2011 Share Posted January 11, 2011 When I try to click ok to accept my min and max values this message pops. What does it mean? What figures am I getting wrong? Is it a bug or am I being stupid? (Stair tool in VW v2011) Quote Link to comment
Christiaan Posted January 11, 2011 Author Share Posted January 11, 2011 pfft, can't work the thing out Quote Link to comment
Bryan G. Posted January 11, 2011 Share Posted January 11, 2011 Christiaan, I am wondering if the module was written using the piece Escher's Relativity as a basis for calculation? Quote Link to comment
VincentCuclair Posted January 11, 2011 Share Posted January 11, 2011 (edited) I think they are somehow also connected to some/all of the other values ie. Number of risers etc. Try checking the other values that may determine rise and run in general........and try locking and unlocking some of the padlocks. Edited January 11, 2011 by Vincent C Quote Link to comment
mike m oz Posted January 12, 2011 Share Posted January 12, 2011 Christiaan you seem to have hit on a combination that won't work. Even when you change the 2R + G max value to 1000 it still doesn't work. Submit it as a bug. Quote Link to comment
michaelk Posted January 12, 2011 Share Posted January 12, 2011 While you're at it, submit the missing preposition in the warning. "The Riser Height must be equal to or less than the maximum Riser Height." mk Quote Link to comment
VincentCuclair Posted January 12, 2011 Share Posted January 12, 2011 I guess the whole tool won't work if there is an option to switch off the max/min settings completely...!? Quote Link to comment
Christiaan Posted January 12, 2011 Author Share Posted January 12, 2011 Christiaan you seem to have hit on a combination that won't work. ... Submit it as a bug. Heh, trust it to be the UK building regs standard for stairs in blocks of flats, our most common stair configuration. Quote Link to comment
Christiaan Posted January 12, 2011 Author Share Posted January 12, 2011 While you're at it, submit the missing preposition in the warning. "The Riser Height must be equal to or less than the maximum Riser Height." Even then it isn't helpful as there is no "Riser Height" setting in the window. I assume it's meant to say "The Minimum Riser Height must be ..." Quote Link to comment
Dieter @ DWorks Posted January 12, 2011 Share Posted January 12, 2011 Just set the min. values very low and the max. values very high. The tool sometimes refuses to draw a perfectly correct stair because of these values, when hten setting them too low and too high, there is no more problem. Quote Link to comment
Christiaan Posted January 12, 2011 Author Share Posted January 12, 2011 If we forget UK blocks of flats (a standard stair symbol is all they need Not true by any stretch, at least not in London where our sites are nearly always as tight as a duck's chuff. Floor-to-floor heights are often different between projects and nearly always different between floors. Length and styles of flights always vary. The only constant is the building regs minimums and maximums. Quote Link to comment
Christiaan Posted January 13, 2011 Author Share Posted January 13, 2011 I've got it. The pop up window is referring to the Riser Height under General Geometry in the main window rather than the Min./Max. Settings window. I had to go out of Min./Max. Settings window and lower the Riser Height in the main settings. Horrible stuff. Being that the Riser Height wasn't locked my Min./Max. Settings should have overridden the Riser Height. So, although obscure, Petri was correct. Rules first, goal posts after that. Quote Link to comment
Christiaan Posted February 18, 2013 Author Share Posted February 18, 2013 I've got it. The pop up window is referring to the Riser Height under General Geometry in the main window rather than the Min./Max. Settings window. I had to go out of Min./Max. Settings window and lower the Riser Height in the main settings. Horrible stuff. Being that the Riser Height wasn't locked my Min./Max. Settings should have overridden the Riser Height. So, although obscure, Petri was correct. Rules first, goal posts after that. Actually this is stupid. If we change the rules the goal posts should just move automatically. It's a computer! Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted February 20, 2013 Vectorworks, Inc Employee Share Posted February 20, 2013 Its a good practice that when drawing stairs, you should start by selecting the style for the intended use (either on Vw 2011 or newer) on v2011 you can create a style with broader boundaries and use it if your stair does not need to follow any code rules as mentioned before, otherwise select the appropriate code rule (always good to check the latest code ruling to match the intended style) on v2013 you have a checkbox to select whether you what to use min/max values or not. Quote Link to comment
Christiaan Posted February 21, 2013 Author Share Posted February 21, 2013 Okay, so set the min./max before placing the stair on the design layer? Quote Link to comment
