MNewland Posted January 8, 2011 Share Posted January 8, 2011 In v2011, is there a way to have classes referenced to or from a single source file. Workgroup Referencing seems to work only with layers, symbols, and viewports. It sure would be useful to have a class standard that is the source for all other classes in other files?with the option to customize the class definition in a working file. Of course, class standards are available when you create a new class, but that's not the same thing as referencing. Quote Link to comment
michaelk Posted January 8, 2011 Share Posted January 8, 2011 If I understand your question, yes, you can reference classes from other files. Navigation Palette, Classes Tab > New > Select "Import Classes" Click "Choose" > Navigate to source file for classes > select which classes to import > OK hth mk Quote Link to comment
MNewland Posted January 14, 2011 Author Share Posted January 14, 2011 Well, that's not referencing, that's just importing. Hum . . . I guess this is something to add to the Wish List. Thanks for your response, though. M. Quote Link to comment
michaelk Posted January 14, 2011 Share Posted January 14, 2011 You're right. It's not a real reference.... Quote Link to comment
Tobias Posted January 14, 2011 Share Posted January 14, 2011 Yes there is a way. There is a good thread on the subject, but I can't find it now. Basically, set up a file with the classes as you'd like them. Create a symbol (ie a rectangle),with the rectangle set to the class you'd like to reference. Create a new file, select the symbol in the resource browser of the appropriate class you'd like to reference, Left click on the symbol From the drop down, select 'reference' In the dialogue that pops up, select 'update class definition...' I've set it up, and it works well. I've set up symbols containing a few rectangles set to classes in various groups, (i.e. a symbol of bunch of rectangles individually set to my various annotation classes) Now, when you make a change to the master class file, save it,and update the reference in other files, the class changes take effect. Very handy. Again, there is a good thread on this, search and you will find..... Quote Link to comment
Dieter @ DWorks Posted January 14, 2011 Share Posted January 14, 2011 Yes there is a way. There is a good thread on the subject, but I can't find it now. Basically, set up a file with the classes as you'd like them. Create a symbol (ie a rectangle),with the rectangle set to the class you'd like to reference. Create a new file, select the symbol in the resource browser of the appropriate class you'd like to reference, Left click on the symbol From the drop down, select 'reference' In the dialogue that pops up, select 'update class definition...' I've set it up, and it works well. I've set up symbols containing a few rectangles set to classes in various groups, (i.e. a symbol of bunch of rectangles individually set to my various annotation classes) Now, when you make a change to the master class file, save it,and update the reference in other files, the class changes take effect. Very handy. Again, there is a good thread on this, search and you will find..... Completely correct. I'll also do this for all of my library files. For creating the symbol, you can use my command pio that will do just that of all classes in the document. Here is the link: DListClasses Quote Link to comment
Tobias Posted January 14, 2011 Share Posted January 14, 2011 DWorks, that tool is a big help. Thank you. I only wish I had found it a few weeks ago. Quote Link to comment
MNewland Posted January 15, 2011 Author Share Posted January 15, 2011 Great help! Thanks?just create a symbol that embodies all your classes in a source file and reference to that. Brilliant. M. Quote Link to comment
