Kimcz Posted January 5, 2011 Share Posted January 5, 2011 I am editing a symbol, adding a polyline object. It comes into the symbol in edit, but when I go back to the symbol, the addition has disappeared. This, after many frustrating hours trying to find out the problem, I have noticed that when I switch to Top View, the addition shows, whilst in Plan view it doesn't. I have achieved the addition in one case, but this was by accident. Somehow the polyline seems to have gained a 3D characteristic, but I can't see this. I can make it show in 2D Plan view by getting the object from the accidental success by adding the symbol to the edit symbol process, and converting to group, and stripping everything else, a real bind. I have checked the usual class settings. Does anybody have any ideas, or perhaps come across this before. 2011 SP2 Windows XP Quote Link to comment
Jonathan Pickup Posted January 5, 2011 Share Posted January 5, 2011 Vectorworks symbols have two parts, 2d and 3D. where do you want the polyline to be, in the 2D part or the 3D part. I think you need to look at the fundamentals of creating symbols. Quote Link to comment
crosetti Posted January 5, 2011 Share Posted January 5, 2011 right clicked on the model, chose edit. In the "Edit Symbol" window where it says Double Click, in the drop down menu chose: Edits the Component Based on View That should do it. Quote Link to comment
Kimcz Posted January 6, 2011 Author Share Posted January 6, 2011 Crosetti, Thanks for your response. I did somewhat you advised, as my object was in 2D not a model in 3D. However the object had a plane attached to it, for some unknown reason. It has solved my problem. Thank you. Thank you also Jonathan Pickup. I will also look to the links you suggest, but I have been using Vectorworks since its Minicad 6 days, and obviously I have to be careful now, in 2011, "planes". Happy New Year to all. Quote Link to comment
