Don@Black Dog Posted December 29, 2010 Share Posted December 29, 2010 I am trying to insert a vent or register for AC in a wall. So far I have used both the door and window tools, but both cut all the way throught the wall. Is there a way to do a partial cut? I could use a symbol but prefer a plug-in object since the sizes frequently change throughout a house. Thanks! Quote Link to comment
Jonathan Pickup Posted December 30, 2010 Share Posted December 30, 2010 draw a 3D object for the AC duct, then create a wall recess... I covered this in the Vectorworks subscription service in September 2010 Quote Link to comment
CipesDesign Posted December 30, 2010 Share Posted December 30, 2010 Hmm. What about a slightly different approach? Instead of inserting into a wall, how about just placing on the surface of the wall. You could use a very simple 3d (or hybrid) symbol for this... Quote Link to comment
Don@Black Dog Posted December 30, 2010 Author Share Posted December 30, 2010 Thanks for the input, guys. Jonathan, I was hoping for a simpler method. I am using the 3d object, wall recess method for some large under-window heater units in an apartment, as well as some doors in thick walls with a recessed raised threshold, but it is a bit of a p-i-t-a to use for multiple items of varying sizes, even to copy and paste. Peter, this might work. Also, I guess I could make multiple copies of varyng sizes. I guess I was spoiled by the adaptibility of PIO's. Thanks again and good to hear from both of you again! Quote Link to comment
Don@Black Dog Posted December 30, 2010 Author Share Posted December 30, 2010 Well, I very successfully deconstructed a window pio and made a good symbol. Is there a way to associate a recess in a wall as part of the symbol or is it always a separate endeavor? (I think that is self answering....) Always an adventure. Quote Link to comment
Robert Anderson Posted January 3, 2011 Share Posted January 3, 2011 Don, when Peter and Jon are talking about "wall recesses" I think they are talking about Wall Features, which were introduced in (I think) Vectorworks 2009. The Wall Features functionality is dead-simple to use, which is I suspect why they suggest it. That said, you can make a symbol that does not break the wall (by stacking two 2D loci). But if you want a custom 3D subtraction from the wall that leaves the wall surfaces, you'll need to upgrade also. Quote Link to comment
Don@Black Dog Posted January 3, 2011 Author Share Posted January 3, 2011 Thanks, Robert. I also realized upon looking further (duh), that when making a symbol, teh insertion properties could be set to break a wall all, part or not at all, which worked perfectly for my use (insert on one side, dont break the other). I used the wall recesses for openings below large window sills and will probably do so again for niches. With the symbol, I wanted something I could copy and paste quickly rather than create an opening for each one which then has to be moved if the grill location changes (which is fairly simple I have found, but still an extra step). Thanks again. Quote Link to comment
Dieter @ DWorks Posted January 4, 2011 Share Posted January 4, 2011 You can specify a custom wall opening in your symbol. That's much much easier to use than wall features. And they can go beyond the end of the wall. Just use 2 loci on top of each other and set the opening without caps, this way the 2D wall will not be broken. Quote Link to comment
Don@Black Dog Posted January 4, 2011 Author Share Posted January 4, 2011 Very cool. Thanks. How do you add the loci? ( I could look it up but this is easier...) Quote Link to comment
Dieter @ DWorks Posted January 5, 2011 Share Posted January 5, 2011 Very cool. Thanks. How do you add the loci? ( I could look it up but this is easier...) From the basic tools palette. Quote Link to comment
