W Wilkerson Posted December 22, 2010 Share Posted December 22, 2010 (edited) Many of my lighting symbols have multiple symbols within them to indicate lens degrees, wattages, etc. As of updating to SP4 ( I think that is when it happened), when I place one of these fixtures in a document, it creates not one lighting device but one for each component symbol. These symbols are then treated as a multi-circuit unit that can be moved around and all of the elements follow. However, individual elements can be deleted. For example, my source 4 19? 750watt has the following components: - 2D/3D symbol for the clamp, yoke, and body of the fixture - 2D/3D sybmol for the lens and a color code thereof - 2D symbol to highlight what is for me an uncommon wattage Instead of a single 19? unit, I get three separate devices each with their own channels, dimmers, etc. Grouping does not work. If I make that three into a symbol first so that their the first step within the symbol contains only one symbol and possibly some text, it works. Only symbol components within a symbol seem to do this unless one "protects" them as noted above with one additional layer. Any thoughts of how to avoid that step? I have included a sample file that highlights this issue with Source 4 PARs. Thank You, weston Edited December 23, 2010 by W Wilkerson Quote Link to comment
Vectorworks, Inc Employee klinzey Posted December 23, 2010 Vectorworks, Inc Employee Share Posted December 23, 2010 If the symbol you are placing only contains other symbols that Spotlight will see it as a multi-circuit symbol. If there is anything else in the symbol then it will be placed as a single lighting device. So if you make the wattage just text and not a symbol it will insert as a single lighting device. Quote Link to comment
