nikolauz Posted December 20, 2010 Share Posted December 20, 2010 Hi, in the attached file I show the very simple work I need to draw. I am drawing in 2D using vectorwork 2010 basic. What I wanted to do was: - draw the inner perimeter (lines+arc) - do an offset - fill the outer figure - add a rectangle where there's the opening Is this the correct (best practice) way to draw my attached file? Thank you Nicola Quote Link to comment
Dieter @ DWorks Posted December 20, 2010 Share Posted December 20, 2010 Use walls instead. There faster to draw and easier to edit then poly's. Quote Link to comment
