irregular polygon tool/extrude
Twickenhaman
David if you double click on your extrude so you can select the 2D shape it was created from you will find the shape is unclosed. Checkmark the Closed option on the OIP and you will find the extrude is now a solid.
Unclosed polygons extrude the polygon shape only. Closed polygons extrude the polygon shape as a solid.
Or if the polygon has to be exact use the Reshape tool to move the two end points so they are exactly coincident. VW will then recognize that it is a closed poly, with the correct number of vertices (instead of an extra vertex and (probably very short) side.)
When you are drawing the poly, and are ready to put the last point, make sure you have snapped to the beginning point and the poly will close automatically.
