tamarindi
section viewport on design layer looks bad...
Peter,
It didn't affect the VP on the design layer.
un-checking the "display objects beyond view plane" shows that the extra lines are from the windows. It looks like a bug. since section VP on sheet is ok....
Hmmm. I played around with one of my files and found that Design Layer Section VP's will exhibit a lot of triangulated lines from windows and doors when in Wireframe, but the lines go away when the view is rendered. I have attached three screenshots: Wireframe, Hidden Line and Open GL. Although this *might* be a bug, it is more likely that it is working as designed and that the intent is that one of the render modes be used to view these SVP's...
OK. got it.
Section VP on sheet layer defines from design layer in the fact the you can't render only the VP. The control goes from rendering modes and not info pallet.It means you render the layer.
But still.... it looks like cuts being made in the old cut command years ago...
