Dustman Posted December 13, 2010 Share Posted December 13, 2010 Properety Line issues Hello All, Hopefully there is a simple solution to this When drawing a property line everything works well however I am getting an issue of a line shooting off to the top right edge of the boundary This is not the area where the boundary end point joins the start point so totally confused on how or why this is happening. I cannot remove by double clicking on the property line and removing it as there is no length or bearing asociated to this line. Any help would be much appreciated. I am using the latest service pack of VW2010 Architect. See attached screenshot Quote Link to comment
Peter Eichel Posted December 14, 2010 Share Posted December 14, 2010 The line is an external connection to the text which displays the area of the property. If you turn on scaling a blue dot will appear near the text. Grab it and drag it to the center of the property, after which, the line should disappear. You can also ungroup the property and delete the line. It is a bug that I believe has been corrected in VW's 2011. Quote Link to comment
