sarah_earney Posted December 9, 2010 Share Posted December 9, 2010 (edited) So this is a bit of an odd one, we have someone here whose computer was running VW12.5 fine, then someone else used it and now when you go to draw a line using the line tool you can't see the line you're drawing... It feels like someone has hit a little known shortcut by mistake that makes the line you're drawing invisible...? I've been through the preferences to see if there are any obvious tick-boxes that would sort it out but can't see an obvious solution. Computer is a new 27"imac, running OS 10.6, with VW 12.5. Edited December 9, 2010 by sarah_earney Quote Link to comment
michaelk Posted December 9, 2010 Share Posted December 9, 2010 Computer is a new 27"imac, running OS 10.6, with VW 12.5. That could be your problem. 12.5 isn't supported on 10.6 and gets flaky... Quote Link to comment
Ray Libby Posted December 9, 2010 Share Posted December 9, 2010 Make sure your line color isn't set to white. michaelk is correct, that version is not supported on 10.6. Quote Link to comment
Kaare Baekgaard Posted December 9, 2010 Share Posted December 9, 2010 I have once tried to accidentally draw in a class, that was set to invisible and got the same phenomenon. Perhaps that is the problem? Quote Link to comment
gScott Posted December 12, 2010 Share Posted December 12, 2010 it happens if you work in the annotations of a viewport with an active class that is set to be not visible in that viewport... i don't think it happens on a design layer... Quote Link to comment
