Mecacarl Posted December 4, 2010 Share Posted December 4, 2010 What's the best and easiest way to add molding to walls. Crown molding & base? Quote Link to comment
Benson Shaw Posted December 4, 2010 Share Posted December 4, 2010 Extrude Along a Path. Many discussions about this on this forum. Here is one recent thread. http://techboard.nemetschek.net/ubbthreads.php?ubb=showflat&Number=134803&Searchpage=1&Main=27652&Words=crown+molding&Search=true#Post134803 Post back if you can't make it work. Good Luck! -B Quote Link to comment
CipesDesign Posted December 4, 2010 Share Posted December 4, 2010 If you want to create an accurate model then probably using Extrude Along Path (EAP) is the best solution. One tip is to place these types of objects into their own discreet class(es) as they will for sure add to the render time. Then you can make the class(es) invisible as desired... [Another method that sort of works is the new Wall Sculpting feature (new in 2011). The only problem with this is that as far as I know it will not go around corners, which makes it pretty much useless for these sorts of moldings.] EAP has one funny quirk: you cannot set the origin point of the profile shape until after the object is created; it will always use the profile's center line, which makes it tricky to guess. The solution is to trace the room perimeter and use that for the path object. After creation you can double click to enter/edit the profile and move it so that its edge aligns with the little center marks that will now be visible (in the edit window). All this sounds harder than it really is. Once you try it once and see for yourself it'll get very fast. Especially if you save a library of profiles to use as needed. One other tip: curves are very render-intensive. Try to keep your shapes as simple as possible in order to get the quality you need without overdoing it. Quote Link to comment
starling75 Posted December 4, 2010 Share Posted December 4, 2010 What about this plugin in Vectordepot... http://www.vectordepot.com/market/VM-042Mouldings.html Quote Link to comment
Mecacarl Posted December 5, 2010 Author Share Posted December 5, 2010 (edited) Thanks for the help. For some reason when I create a Poly Line I'm only able to select "Extrude" and not "Extrude Along Path" why is this? I'm still using VW 12.5. Also, I'm able to get profile drawings of molding and extrude them, but it's hard to place them where I want them to go. Is there a better way. With the method you mentioned, Im I able to get any shape I desire? Do you have examples for the methods your talking about (i,e. Pictures) Edited December 5, 2010 by Mecacarl Quote Link to comment
CipesDesign Posted December 5, 2010 Share Posted December 5, 2010 Create the profile shape, then create the path shape, then select both, then EAP... Quote Link to comment
Pat Stanford Posted December 5, 2010 Share Posted December 5, 2010 Extrude along Path requires at least two objects (the profile and the path) to be selected before you execute the menu command. Could that be the problem? Quote Link to comment
