MattG Posted December 2, 2010 Share Posted December 2, 2010 I am finding in a project I am working on all of my text is not appearing in a isometric, front, right or any 3d view when I apply a hidden line render. Curious to know if this is something that others are seeing or just me and if anyone can think of any obvious setting I might be missing. Examples are if I have a dimension that's plane is set to 3d and it is showing the elevation of a extrude when I look in wirframe it appears correct but the hidden line the text portion goes away while the leader lines are still rendered. I also have some text that is flat on the ground labeling a area and it is on the 3d plane, but when I go to hidden line it disappears. Matt Quote Link to comment
CipesDesign Posted December 2, 2010 Share Posted December 2, 2010 Hi Matt, Have you updated your VW 2011 to SP1? I'm pretty sure this (or something very similar) was fixed in that release... If you have updated and are still seeing the problem please, if you have time, submit a bug! Quote Link to comment
Horst M. Posted December 2, 2010 Share Posted December 2, 2010 (edited) Hallo matt, I have the same experience with the VW2011SP1 Trial The 3d text doesn't show in Viewports in line render mode. In FQRW and other Render Modes the Text is unreadable up to 600 dpi because of Pixelation. My solution was: duplicate the viewport and allign the copies set the upper viewport to WireFrame Render Mode and make all Classes execept Dimensions invisible. make the dimensions Class in the rendered Viewport invisible ---> The dim. text is readable and 3d dimensions in VW are no longer a dream! juhu. example attached Edited December 2, 2010 by Horst M. Quote Link to comment
CipesDesign Posted December 2, 2010 Share Posted December 2, 2010 I suggested to Matt (via PM) that he might be able to use the older method of duplicating and stacking VP's, setting the topmost VP to wireframe with "Dimension" as the only visible class. Not ideal, but perhaps an adequate "gotta get it done today" work-around... Quote Link to comment
MattG Posted December 2, 2010 Author Share Posted December 2, 2010 (edited) My issue is more in that some of the text I want to see is in the 3d portion of symbols that illustrate what they are. I do not wish to go through the various symbols reassign this text to a class and then reproduce this. Just a bug I guess. Edited December 2, 2010 by MattG Quote Link to comment
MattG Posted December 2, 2010 Author Share Posted December 2, 2010 (edited) All the text that is "flat" on the ground does not render as well as the signs abouve these display walls. Matt Edited December 2, 2010 by MattG Quote Link to comment
Horst M. Posted December 2, 2010 Share Posted December 2, 2010 Hi Matt, yes it's a bug, and it's anoying. But the Method with the duplicated viewport ist the only Way to work arround this Problem. And for me its better than waiting or just missing 3d Dimension and text capabilities. Besides that I'm pretty shure, it is the only method to use the 3d Text in FQRW without having the Problem with pixeled and unreadable text in 3d. Quote Link to comment
GWS Posted December 2, 2010 Share Posted December 2, 2010 I use the doubling up of viewports and put the text in wireframe method. Really tiresome but the rendered text is useless, just too pixelated. Let's hope it gets fixed in SP2 Quote Link to comment
GWS Posted December 4, 2010 Share Posted December 4, 2010 (edited) I am having problems export files with 3D text as a pdf. Please see attached I have another sheet with 3D text that exports fine and I can't for the life of me see what the difference is. Both texts are in viewports and they render properly in VW. I can also export properly by going through the print dialogue box and 'save as pdf' (this is a mac thing) which works well. Any thoughts? Edited December 4, 2010 by GWS Quote Link to comment
GWS Posted December 15, 2010 Share Posted December 15, 2010 I see that SP2 hasn't fixed this problem. Surely this is crucial and should have been dealt with in the update Quote Link to comment
bcd Posted December 16, 2010 Share Posted December 16, 2010 I believe it's been fixed for new files created in SP2 but not for earlier files now working in 2011-SP2. Quote Link to comment
