bjw Posted December 1, 2010 Share Posted December 1, 2010 I'm having a problem where I can see the emitted light in Fast Renderworks but not in the "with shadows" mode or Custon RW. I've doublechecked that my default instrument texture doesn't cast shadows, and I can see that the emitter is on in all modes. I'm sure there's a simple fix for this, I just can't figure it out. Help is appreciated Quote Link to comment
Vectorworks, Inc Employee klinzey Posted December 1, 2010 Vectorworks, Inc Employee Share Posted December 1, 2010 You probably have something else blocking the light. Try moving the lighting device away from the lighting position. Usually it's the lighting position or some other close by geometry that will cast the shadow. Quote Link to comment
bjw Posted December 1, 2010 Author Share Posted December 1, 2010 That's what I initially thought, but positions are all turned off right now. I tried deleting it, but to no avail. Quote Link to comment
bjw Posted December 1, 2010 Author Share Posted December 1, 2010 Problem solved--I was using an old version of the instrument body. Quote Link to comment
