Kaare Baekgaard Posted December 1, 2010 Share Posted December 1, 2010 (edited) So now I can't convert a solid into nurbs surfaces (for crying out loud). I get a message informing me, that the conversion has failed. I export the object as an IGES file and import it again and - presto - I got my surfaces exactly as I want them. A little hint to the programmers at NNA: How about I get to do that inside Vectorworks? Edited December 2, 2010 by Kaare Baekgaard Quote Link to comment
Horst M. Posted December 2, 2010 Share Posted December 2, 2010 (edited) During experimenting wirh the "stitch trim surfaces tool" in VW2011 to create solids from nurbs surfaces, I saw, that after performing "stitch trim Surfaces" to some nurbs surfaces the result is marked as a CGS solid in the OIP but if I cut it or sutract solids from that Object I see that is not a solid! it is just a Hollow! thats very terrible. Edited December 2, 2010 by Horst M. Quote Link to comment
Kaare Baekgaard Posted December 3, 2010 Author Share Posted December 3, 2010 It is, Horst. But then again stich and trim never did work too well - and there is no history tree either. It is usually better to do a series of 'section solid' operations on a base object although it is more timeconsuming. Other mostly useless commands include 'create fillet surface', 'create planar caps', 'create drape surface' and create interpolated surface. I may have heard of a person, who heard of someone, who once did something useful with one of theese, but that is the closest, I ever got... And then there is the 'multible extrude' command, unchanged for centuries, which still produces a facetted object - not a nurbs solid. Now that I have been beta-testing VW2011 for a while at my own expense, I really hope NNA will throw in a treat with the release of SP2 or SP3 and give us all a powerpack markII. That being said, VW still is a better modeller, than the unilateral focus on the building industry could let you to believe. Quote Link to comment
GWS Posted December 4, 2010 Share Posted December 4, 2010 I have had this problem too. It becomes extremely important when exporting as stl files for 3D printing. Unfortunately the only solution I found was to import it into 'Inventor' which read it as a solid and then re-export it. Not a good solution but ....'needs must when the devil drives' It seems that VW has not improved in this area. Quote Link to comment
