SteveK
Custom Room Finishes
In VW2008 I was able to modify the list of finishes to show only our office standard finishes. I went through the same steps in VW2011 but I don't seem to be changing anything. The default finishes still show up. I can't seem to find anything in the help files that tells me the correct way to customize the list finishes in VW2011. I want the list to show only our finishes and not have to scroll through all of the default finishes. Thanks.
after having drawn your first space object (on a certain computer), right-click PROPERTIES, click ASSIGN ROOM FINISHES.
you get the mask for assigning finishes to ceiling, walls, baseboard and floor.
below this click EDIT FINISHES.
then edit the list for each location; you may not only define your own finishes, you can as well delete all the defaults.
from now on you can choose from your own lists whenever drawing or editing space objects on this computer. the defaults are gone.
works all the same by using the object info palette.
good luck
helmut
