tamarindi 0 Posted November 22, 2010 I am working on a 3D model rendering of a 3 story house. Whenever i try rendering (other then open GL)i get a "cinema 4D not enough memory" alert. if restart the computer, close all background applications - i might be able to render one view, fast render only. After this it does not render anymore... The file size is only 40Mb. I have win7 32bit, 2Gb ram,2 Duo CPU E6750 266GHz I ordered extra 2Gb ram (although max usage is only 3.5..). Is there anything else i can try? I worked so hard on this model, and if i can't render it's a big problem !! Quote Share this post Link to post
grant_PD 168 Posted November 22, 2010 You will experience problems without enough RAM. The rendering engine is 64 bit, and without that passage way it's like a bottleneck. Any hope of upgrading to win7 64bit? Quote Share this post Link to post
tamarindi 0 Posted November 22, 2010 After reading Tamsin's article i now understand it's a must. Too bad NNA does not give this information as part of purchasing instructions. It means another 150$ or so of upgrading OS system + time spending on re-installing or formatting....grrrr.... Quote Share this post Link to post
Tamsin Slatter 248 Posted November 22, 2010 Hi Tami NV does talk this through in the system requirements. And I must also state that a lot of the knowledge in that document has also come from various tech support knowledgebase articles. I just put it all in one place and organised it a bit better. I'm glad it's helping... Quote Share this post Link to post
tamarindi 0 Posted November 22, 2010 Hi Tasmin, I want to thank you again for doing your great work!! I always check system recommendations and try staying up-to-date. In previous versions you were still able to work fine even if you didn't have the full requirements. This time, it appears to be not a recommendation but a MUST. It is a big leap, and not "just" another upgrade. That's why i believe the emphases should be different. Quote Share this post Link to post
Jershaun 8 Posted November 23, 2010 Hi Tamarindi Firstly, there shouldn't really be anything wrong with your current spec pc. I've done models on a Pentium 4HT with 512MB ram (Laptop) while using Cinema 4D 10.1 and I didn't encounter such messages. Have a look at my web site to see if my models are anywhere as close to the complexity of your model. However I've encountered the message while using lightworks in previous versions of vw. Personally, I think the problem is possibly a corrupt object or group or something so I would first suggest you check your model throroughly to track down the problem. Open a blank new drawing (a test drawing if you like) and copy and paste sections of your model rendering each time until the message comes up-then usually it's the last thing you copied and pasted that will be the problem. Best of luck. Quote Share this post Link to post
tamarindi 0 Posted November 23, 2010 Hi Shaun, Your models are very nice!! pretty much what i do. I will try your suggestion regarding corrupted objects. Quote Share this post Link to post
tamarindi 0 Posted November 24, 2010 Update: Before checking for corrupted objects - I exported the file to VW2010. It renders final-quality in minutes, no crashing, no memory issues !!! Quote Share this post Link to post
Jershaun 8 Posted November 24, 2010 I would submit this as a bug with the necessary file if you can. Quote Share this post Link to post
Benson Shaw 405 Posted November 25, 2010 Just speculating - similar to corrupt object idea: Wireframe views are all good? OpenGL renders OK in VW2011, but Renderworks fails/crashes? Did this VW model begin in a version prior to VW2011? If so, could this be an example of a texture not translating properly from the Lightworks engine to the Maxon engine, therefore causing render fail in VW2011? -B Quote Share this post Link to post
tamarindi 0 Posted November 25, 2010 Shawn, The file was created by another architect on a previous version.They used simple 2D objects. They draw in 2D using openings. no textures. no classes or layers. I replaced or updated almost everything. So i doubt if it's a texture issue. Possible issues: walls -> i used their old objects but added wall styles and textures windows and doors -> i used what they put, but edited settings and classes. The render does not crash.It stops with the prompt: "error: cinema 4D not enough memory"... Quote Share this post Link to post
David Ormsby 2 Posted December 9, 2010 Tami I'm not running 2011 yet, but I do use C4D everyday. I've found that C4D import always coverts objects to meshes. When I get the out of memory error, I'll need to go to VW prefs/3D tab and lower the setting of the 3D conversion a notch. If you have a lot of curves this may help. Quote Share this post Link to post
