user Q Posted November 20, 2010 Share Posted November 20, 2010 how do you adjust the line type scale so it looks correct in the viewport? i changed the scale of the design layer and it looks right in model space, but it does not change the view port lines (& it does not match the other layers.) thanks for any help Quote Link to comment
Ozzie Posted November 20, 2010 Share Posted November 20, 2010 Select the VP and in the OIP - have a look in Advanced Properties Quote Link to comment
user Q Posted November 20, 2010 Author Share Posted November 20, 2010 sorry for being so dense-but. . . model space is 1:1 & view port is 3/16=1-0 i am changing the dashed line 'dashed line scale' and updating but nothing is working. the scale factor for 3/16 = 64 so i entered 64, then tried 1/64, then random numbers - nothing is changing the appearance. AAAAAAAAAAAHHHHHHHHHHHHH! Quote Link to comment
CipesDesign Posted November 21, 2010 Share Posted November 21, 2010 Try entering .0156 and see what happens. FWIW 1/64= .0156 Quote Link to comment
CipesDesign Posted November 21, 2010 Share Posted November 21, 2010 Try entering .0156 and see what happens. FWIW 1/64= .0156. Also you might find this link useful (or maybe not, but...) http://archtoolbox.com/representation/cad/19-scalefactor.html Quote Link to comment
user Q Posted November 21, 2010 Author Share Posted November 21, 2010 entered .0156 & still no change in appearance. the line is the default default dash style-1 in model space - it is not the layer default line type. Quote Link to comment
CipesDesign Posted November 21, 2010 Share Posted November 21, 2010 Not sure this will help, but do you perhaps have "zoom line thickness" pref turned off? Quote Link to comment
Benson Shaw Posted November 21, 2010 Share Posted November 21, 2010 (edited) Try adjusting both the line weight scale and the dash scale in VP Advanced Properties. I find that line weight has a lower limit beyond which the VP Advanced Properties will not change the stroke (line weight/width). Anyway, when the DL and VP have really different scales, the dash scale needs help from the line weight scale. Both properties at same scale can mush up the spaces btw dashes. -B Edited November 21, 2010 by Benson Shaw Quote Link to comment
user Q Posted November 21, 2010 Author Share Posted November 21, 2010 thanks for the great advice - but still nothing!! tried lots of line weight & dash line scale combination's and the only thing that changes is the line weight scale. when i switch the DL to 3/16 the dashes show fine but it still does not change the way displayed in the VP tried several DL line thicknesses & line types also. the dashes are not showing up in the VP. 'zoom line thickness' was off - now it is on - tried everything again - no luck Quote Link to comment
Benson Shaw Posted November 21, 2010 Share Posted November 21, 2010 Maybe an example from you would help? Switch to Full Reply and use the File Manager to post a new VW file with just a few DL objects and a single Sheet Layer View Port which demonstrates the situation. Use the layer and VP scales you have now, and the same line/dash styles. Also, it helps with troubleshooting to know your VW version(s) and a bit about your computer system. Please use the My Stuff tab on this forum to create a profile & signature showing this info. -B Quote Link to comment
Peter Eichel Posted November 22, 2010 Share Posted November 22, 2010 Q: It's good practice for your design layer to be at the same scale you intend for the viewport on the sheet layer. When you change a design layer to, lets say (1/4"=1'-0") you are still drawing at a 1:1 scale on the design layer. By doing so you are "calibrating" the design layer to the intended viewport which ensures the scale of text and lines remain unchanged. Quote Link to comment
user Q Posted February 26, 2011 Author Share Posted February 26, 2011 !!!!!!the view port was set to 'top' not 'top/plan'. sorry for the novice stupidity & thanks again for the help! Quote Link to comment
user Q Posted March 1, 2011 Author Share Posted March 1, 2011 (edited) PETER - i understand, but what about using another design layer as an underlay? do all visible layers have to be @ the same scale? or do they show up as 1:1 when ever you are in 'model space'? Edited March 1, 2011 by user Q Quote Link to comment
Benson Shaw Posted March 2, 2011 Share Posted March 2, 2011 (edited) In Unified View, layers which differ in scale from the active layer do not display. There is an "Ignore" checkbox in the UniView Options, but checked or unchecked, I can't get different scale layers to display. In non unified view, all visible layers display when any of the show other options are selected in layer visibility. -B Edited March 2, 2011 by Benson Shaw Quote Link to comment
