GWS Posted November 20, 2010 Share Posted November 20, 2010 Is there a way to set a keyboard shortcut (or another quick method) to toggle between screen plane and layer plane? Quote Link to comment
MullinRJ Posted November 21, 2010 Share Posted November 21, 2010 You can toggle it with this one line script SetPref(1099, not GetPref(1099)); { toggle Screen/Layer Plane mode } To make it run off a hotkey, see Robert Anderson's post (it's the last option): What do I do with a VectorScript, anyway? If you need help with the Workspace Editor, check the online help or write back here. HTH, Raymond Quote Link to comment
GWS Posted November 21, 2010 Author Share Posted November 21, 2010 Many Thanks, Raymond. Quote Link to comment
mar schrammeyer Posted November 21, 2010 Share Posted November 21, 2010 Would that be quicker then this? Quote Link to comment
GWS Posted November 22, 2010 Author Share Posted November 22, 2010 Actually the main issue is this: I set the screen plane as active, I then select the mirror tool and mirror my object and discover that VW has decieded to switch back too layer plane, meaning that my object has been mirrored in a different plane. I then undo and start again. I was trying to find a way of maintaining my selection and a keyboard shortcut is often done with one hand while the other is on the mouse!! Quote Link to comment
VincentCuclair Posted November 23, 2010 Share Posted November 23, 2010 I'm not sure but doesn't the snap to working plane constraint have something to do with this? Quote Link to comment
Lyly L Posted November 25, 2010 Share Posted November 25, 2010 You can toggle it with this one line script SetPref(1099, not GetPref(1099)); { toggle Screen/Layer Plane mode } To make it run off a hotkey, see Robert Anderson's post (it's the last option): What do I do with a VectorScript, anyway? If you need help with the Workspace Editor, check the online help or write back here. HTH, Raymond Such a very amazing link! Quote Link to comment
