manfredi
wall and slab components
I don't know if I'm missing something - I just upgraded to VWA2011, and I can't seem to see the components in a section viewport. I've tried switching all the usual display buttons on, and I've checked that my line thickness is showing and my sheet layers are not black and white only, but nothing happens. I've tried tweaking the section style line thickness and colour, but nothing happens either, the section looks white with max .35 wide lines, even no matter what rendering I apply to the viewport...
This happens both on new files with a couple of walls as test, and on previous files that worked until a few days ago in VW2008
Can anyone help? is this a bug?
Thanks
Are all of the appropriate layers and classes turned on in the Section Viewport?
99% of the time when things disappear it is a class visibility issue.
Is the viewport cropped? If so, could the crop have moved so that it is showing a blank area instead of what you want?
Can you see anything in the viewport?
the viewport shows everything as it should, but the actual section appears colourless or not as a proper section, if you know what I mean... not too thick and with no shading or colour within it.
got it thanks, I hadn't checked the attributes button as per Wes's second screenshot two posts ago on this thread... doh!?
Thanks for this guys
m.
