da_muel Posted November 18, 2010 Share Posted November 18, 2010 Hi, Im looking for some info or a script that will allow me to change the class of several symbols at the same time. I know I can right click on the individual symbols in the symbols folder but is there any way to change the class of multiple symbols. I have a library of several hundred hybrid symbols and I need to change most of their classes. Any pointers . . . Thanks Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted November 18, 2010 Vectorworks, Inc Employee Share Posted November 18, 2010 Hello da_muel, Under the Tools/Utilities/ submenu, you should find a "Set Default Symbol class" command. this will set the default class of ALL symbols in the active document. If you don't want all of them changed, create a new file, import the ones you want to change, run the command, then import them back into your document (replacing the old ones). HTH, Quote Link to comment
da_muel Posted November 19, 2010 Author Share Posted November 19, 2010 Hi Matt, Brilliant - just what I was after. Thanks Sam Quote Link to comment
