James Russell
Help with Tool Creation
Hi all,
I'm trying to create a new tool for use in our new template. I've been playing with the create custom tool scripts for a while but I am not able to get the result that I want at the moment.
Basically I would like a tool that creates a double line polygon with three components, 30mm as the overall width, broken into two fills, a black fill for 20mm and a 10mm fill in red, see attached pic for details on that part. Using the existing custom create a tool I have this script:
Procedure CustTool;
VAR
Result:BOOLEAN;
BEGIN
PushAttrs;
Result := DeleteAllDLComponents;
Result := InsertNewDLComponent(1, 20, 1, 0, 2, 2, 2);
Result := SetDLComponentName(1, 'BLACK');
Result := SetDLComponentClass(1, 0);
Result := SetDLComponentFillColors(1, 257, 257);
Result := SetDLComponentPenColors(1, 257, 256, 257, 256);
Result := SetDLComponentUseFillClassAttr(1, FALSE);
Result := SetDLComponentUsePenClassAttr(1, FALSE, FALSE);
Result := InsertNewDLComponent(2, 10, 1, 2, 0, 2, 2);
Result := SetDLComponentName(2, 'RED');
Result := SetDLComponentClass(2, 0);
Result := SetDLComponentFillColors(2, 257, 1251);
Result := SetDLComponentPenColors(2, 257, 256, 257, 256);
Result := SetDLComponentUseFillClassAttr(2, FALSE);
Result := SetDLComponentUsePenClassAttr(2, FALSE, FALSE);
SetDLSeparation(30);
SetDLControlOffset(0);
SetDLOptions(1);
CallTool(-218);
CallTool(-218);
PopAttrs;
END;
Run(CustTool);
This works very well for the first part of my little project. The resultant is 3 polygons (as expected), black, red and white. Now for the tricky part.
On completion of drawing the polygons I would like it to select the white polygon and convert it into a Lighting Position Object.
Anyone? It's probably a line like get selected object white convert to lighting position object, but I really don't know the syntax on that.
Any help much appreciated.
Cheers,
James
First of all, why do you use CallTool(-218); two times? I think one is enough.
You can use this at the end of your script:
	DSelectAll;
h:=PrevObj(PrevObj(LObject));
SetSelect(h);
h is the handle to that "base" poly. SetSelect(h) makes sure that that poly is selected after execution.
I have no idea what a Lighting Position Object is (i have a Dutch translation of VW) and can't find it in the menus, so maybe somebody else know a way to Convert it?
BTW, the small component isn't red on my computer, probable because "1251" is not a standard color...
If you need to use this on other computers too, i think its safer to use "7" for red, that's the standard color and will normally work on every drawing.
Result := SetDLComponentFillColors(2, 257, 7);
Maarten,
Thankyou, you are correct, twice was the generated output from the custom tool creation script, and the colour was just something I chose from the palette at random.
I placed:
DSelectAll;
SetSelect(h);
after the Popattrs; and added h:Handle; to the VAR as I thought it should go but once the double polygon is finished being drawn all three polygons are still selected.
Even if I can just look within these three polygons for the one where pen colour=null and that becomes selected. The Convert to Lighting Position Object could be a manual menu job if necessary.
I'll keep playing but any input is much appreciated.
Cheers,
James
Edited by James Russell
Converting to a Lighting Position Object completely by script is not so straight forwards. I can outline the method, but first give DoMenuTextByName a try using Spotlight's Convert to Lighting Position menu item. That should work for you and be within your scripting comfort level.
-Josh
Very strange, i tried it yesterday and it did work, but now i can't seem to reproduce it... I must stop posting things so early in the morning :) .
Oke, here's an other way of doing this:
Procedure CustTool;
VAR
Result:BOOLEAN;
tmph,h:HANDLE;
BEGIN
PushAttrs;
Locus(0,0);
tmph:=LNewObj;
SetDLOptions(1);
CallTool(-218);
PopAttrs;
DSelectAll;
h:=NextObj(tmph);
DelObject(tmph);
SetSelect(h);
DoMenuTextByName('Convert to NURBS',0);
END;
Run(CustTool);
You need to adjust the last line DoMenuTextByName('Convert to NURBS',0); by something else. I don't have Spotlight so i can't call that menu item. It should be something like DoMenuTextByName('Convert to Lighting Position Object',0);
Thankyou both or your help, the DoMenuTextByName command is awesome, perfect some would say. The only issue I'm having which feels like a bug is when the convert to light position is done, the object becomes unselectable, try the script below if you have spotlight.
Procedure CustTool;
VAR
Result:BOOLEAN;
BEGIN
PushAttrs;
CallTool(-203);
PopAttrs;
DoMenuTextByName('Convert to Light Position',0);
END;
Run(CustTool);
It should let you draw a rectangle and then convert it to a light position. I find I cannot select the object only the label handle. When I touch this or nudge the object it returns to normal.
I tried a Hmove on it by a fraction but to no avail.
Frustratingly close, does anyone else have this?
J
