select
vhector
Hi,
I often get cad drawing with elements like parkings, trees etc. in the same layer and are not symbols.
You have alot of selection ways, like color, class line type and other types. Is there also a way to select on objects with same area or area between, like 12,1m2 and 12,8m2.
Vincent
It is possible to select objects with any type of criteria.
First you want to isolate objects based on the same attributes you find in the custom selection command as you said by color,type,etc. using
PROCEDURE ForEachObject(callback:PROCEDURE; c:CRITERIA);
Then in the callback procedure you can get other attributes from the objects returned and then compare the object value with your own value. For areas, it would be:
PROCEDURE SelItem(objHdl: HANDLE);
VAR
curArea: REAL;
BEGIN
curArea:= ObjArea(objHdl);
IF curArea = 1.2 THEN {Assuming the document units are m2}
SetSelect(objHdl);
END;
Vincent
Hi Vincent
If those values are parameters that you can see in the Object Info Palette, then you can also check those value with:
IF GetRField(Handle of parking,Name of Plugin,Name of Field)=12,8m THEN ...
To get the name of plug in and field, you could make a report of those objects, then you can see them in the formula bar.
