wvancampen Posted October 28, 2010 Share Posted October 28, 2010 In 2D, how do you make a window appear with a different (say darker) fill for the cut parts (eg jamb, sash) and lighter fill for the rest (eg the sill below)....as per graphic convention? With a door it's straightforward--the fill attribute appears for the leaf and the jamb/trim, and everything else not. With a window everything (jamb, trim, sash, sill etc) gets that fill. As far as I can tell, differentiating parts via Window Settings/View/Special Classes only affects rendering and 3D, not 2D projections. Quote Link to comment
Guest Wes Gardner Posted October 28, 2010 Share Posted October 28, 2010 Is this what you mean? "Use Part Line Styles" Quote Link to comment
wvancampen Posted October 28, 2010 Author Share Posted October 28, 2010 No. How would you make the jamb, sash and trim darker (like the walls) and the sill light? Again, the door tool does this automatically and as per convention, but the window tool does not....as far as I can tell. Quote Link to comment
scottfdavis Posted October 29, 2010 Share Posted October 29, 2010 Wes & wivc, I have experienced some strangeness regarding the Window Tool display as well. I believe the attached file has an example of what you are looking for: .25 line weight on the jamb & glazing .13 line weight on the sill This is done with Class assignments. But I also wanted to see if you can replicate the strange behavior I am seeing. When you open the file you'll see 2 identical windows. The walls they are in both have the same component structure. If you select one of the walls and delete all the components you will see that the window stops displaying properly. I don't know why this is. The window settings have not changed. If you change the wall back, remove the window and re-place it in the wall you find it displays correctly again. Any thoughts?? Anyone?? Quote Link to comment
Jershaun Posted October 29, 2010 Share Posted October 29, 2010 People, people. What wivc is talking about is "INFILL" colours. At present this isn't possible. I wouldn't hold my breath for this wivc. I've been asking for this for the last 5/6 years but always ignored. I don't use the window tool because it's too buggy. It can't even do sloping brick sills properly interacting with walls. Can you believe a BIM program can't do windows properly? Just make your own window symbols. Add it to the wish list. Quote Link to comment
wvancampen Posted October 29, 2010 Author Share Posted October 29, 2010 Shaun, I'm glad I'm not the only voice crying in the wilderness. (Yes, I know this is unchanged from previous versions). Quote Link to comment
