Gehrk037 Posted October 24, 2010 Share Posted October 24, 2010 Hey everyone - I just started using VWX a few weeks ago. I've been working in the designer workspace, and I've figured out how to make a wall, and I've figured out how to texture things.... except when it comes to the walls... Whenever I try to put texture on a wall, the texture goes on the thickness of the wall, not the face of the wall. Help? step-by-step and layman's terms would be helpful. Thanks! Quote Link to comment
michaelk Posted October 24, 2010 Share Posted October 24, 2010 Select the wall(s) In the OIP select the render tab. In the Part pull down select the Left or Right side. In the texture pull down select the texture. If you are making custom wall styles you can define the textures into the wall style hth mk Quote Link to comment
Gehrk037 Posted October 24, 2010 Author Share Posted October 24, 2010 Thank you so much! Much frustration saved! -Gehrke Quote Link to comment
