nikolauz Posted October 19, 2010 Share Posted October 19, 2010 Hi, using vect. 2010 basic I am trying to draw a flat: what the best way to set a point for a wall? I know that a 10 meters wall has a connection at the 4th meter. I thought that with the tool "measure" I could measure 4 meters and set a point to be use as start point for the other wall? Could you please suggest me how to measure and set a point? thank you nicola Quote Link to comment
J. Johnson Posted October 20, 2010 Share Posted October 20, 2010 Hi Nicola- One way to do this is to simply draw a short line as a marker, and move it the distance you want up the wall to show where you want the connection. Not sure what the tool is called in Italian, but I use "duplicate array" quite often for setting multiple points at the same distance. Hope that helps. Jake Quote Link to comment
mike m oz Posted October 20, 2010 Share Posted October 20, 2010 To do it on the fly: - Use the G key to set a temporary tab at the beginning of the wall (you need to have that option enabled in your 'Smart Points' settings). - Tab into the floating data 'L' field and then enter 4 m. This will give you a temporary snap point at that distance along the wall. You can also parallel copy walls with the Offset tool. Quote Link to comment
