TiTaNiuM sAMuRai Posted January 14, 2002 Share Posted January 14, 2002 Exporting 3500-pix wide images (both pict and jpg) results in a wonky image file in 9.5 and 9.5.0b7 Exporting to 2000-wide seems to work... Quote Link to comment
Matthew Giampapa Posted January 15, 2002 Share Posted January 15, 2002 Image exporting in VectorWorks is handled by QuickTime. You should be able to export at least a 5000 pixel image in most situation, but this will vary by the image format and version of QuickTime used. Updating to the latest version of QuickTime may help you do larger exports. Or you can use the perspective mode of the program and 0 perspective to make several detailed exports and piece them together by hand. Yet another alternative is to use the RenderBitmap tool and copy and paste the image to another program. I am not aware of any size retrictions here, but they will likely vary on the opperating system used. Matthew GiampapaTechnical Support quote: Originally posted by TiTaNiuM sAMuRai: Exporting 3500-pix wide images (both pict and jpg) results in a wonky image file in 9.5 and 9.5.0b7Exporting to 2000-wide seems to work... Quote Link to comment
