Assemblage Posted October 5, 2010 Share Posted October 5, 2010 Apologies if this is in fact an obvious question: Does the new rendering engine significantly speed up section vp processing in addition to more familiar 'picture' renderings? Quote Link to comment
Assemblage Posted October 7, 2010 Author Share Posted October 7, 2010 The VW folk presented here in London yesterday, and I put this question to them. Hidden line section vp's go through the VW side not the C4D engine. Textures, lighting, and the like go through the C4D engine only. I took from this that projects with multiple section vp's (eg internal room elevations) might be best split into a number of files to avoid the long updating times. The other thing we learnt yesterday is that the 64 bit version of VW is due in 2013. Quote Link to comment
Jershaun Posted October 7, 2010 Share Posted October 7, 2010 The other thing we learnt yesterday is that the 64 bit version of VW is due in 2013. If this is true, it just proves what I've been saying for a long time - The development rate at NemV is ridiculously slow. Other major CAD software (AutoCAD, ArchiCAD, etc.) are already 64-bit at this point in time. This is dissappoiting. I hope you're wrong. Quote Link to comment
dontevenjoke Posted October 8, 2010 Share Posted October 8, 2010 Here is some info from Australia's Ozcad (local distributor and developer). 64 Bit Windows While Vectorworks is fully supported in both 32 bit and 64 bit Windows environments, we generally recommend using a 64 bit Windows operating system for Vectorworks 2011. While Renderworks is fully supported in both 32 bit and 64 bit Windows environments, we strongly recommend using a 64 bit Windows operating system for Renderworks 2011, as it will take full use of 64 bit addressing. With those recommendations having been made, we have noticed that drivers for 64 bit Windows can be somewhat more problematic than those for the more mainstream 32 bit versions of Windows. Should you choose to run 64 bit Windows you should make sure that you carefully choose your hardware and driver versions to avoid problems. Quote Link to comment
Ozzie Posted October 8, 2010 Share Posted October 8, 2010 Been running Windoz 7 64 bit on my main drawing puter for 18 months Biggest problem has been VW - not big things - little things Ray Libby had been using 64 bit also but went back to 32 bit because he could not get drivers for his Kensington mouse I think My laptop is 32 bit so I have been able to check some issues Had a quick look at one of the problems where a composed polyline with curves - you could not snap to a point on the poly and draw a line or another poly sometimes - the line would snap to what I think was the centre or part of that arc in the poly VW 2011 Evaluation version I think has fixed this - will have to wait until I get my copy of 2011 but that will not be until SP1 is released Quote Link to comment
Ray Libby Posted October 8, 2010 Share Posted October 8, 2010 VW 2011 SP1 was released today. It looks like Kensington has written a new application for trackballs so I may be going back to 64 bit. Quote Link to comment
mar schrammeyer Posted October 9, 2010 Share Posted October 9, 2010 (edited) SP1 not for OZ Edited October 9, 2010 by mar schrammeyer Quote Link to comment
Jershaun Posted October 9, 2010 Share Posted October 9, 2010 (edited) Whats the point of having a 64-bit rendering engine to render almost infinite amount of geometry when your modeling application can't model infinite geometry because it's not 64-bit? Edited October 9, 2010 by Shaun Quote Link to comment
Assemblage Posted October 9, 2010 Author Share Posted October 9, 2010 I hope you're wrong. It's not from me - I'm quoting VW's CTO addressing a VW conference Quote Link to comment
