ViewPorts
Assembly
I thought this would create a VP on a sheet layer and turn on all the Layers and Classes. But I can't get the layers or classes to turn on?.
The result is a new viewport on the layer I name, but the view port is a red box with cross hatch, I click on the VP and none of the layers or classes are turned on.
I have run with testing procedure that output the layer and classnames to a file. The loops are passing correctly.
PROCEDURE NewVPWithAllOn(SheetLayerName:String);
Const
TurnOn=1;
TurnOff=-1;
MakeGray=2;
DesignLayer=1;
SheetLayer=2;
VAR
LayerHandle:Handle;
ClassName:String;
Result:Boolean;
iTemp:Integer;
hVP:HANDLE;
BEGIN;
LayerHandle:=CreateLayer(Concat(SheetLayerName,'-Sheet'),SheetLayer);
hVP:=CreateVP(LayerHandle);
LayerHandle:=fLayer;
While LayerHandle<>Nil Do
BEGIN;
Result:=SetVPLayerVisibility(hVP,layerHandle,TurnOn);
layerHandle:=NextLayer(layerHandle);
END;
For iTemp:= 1 to ClassNum DO
BEGIN;
Result:=SetVPClassVisibility(hVP,ClassList(iTemp),1);
END;
END;
Could this be a case of when the object is created? Usually objects created in VS don't actually exist and get a handle until the END of the script execution. This means that at least with PIOs you can't create the object and then set the parameters (or duplicate, or rotate, etc). It is likely that the same is true for VPs.
What about getting the existing class/layer visibilities, turning everything on, create the VP and then reset the visibilities?
