MattG Posted September 30, 2010 Share Posted September 30, 2010 A easy one here just a lapse in my memory. I have a database and I want a row to have a suffix of something. Say "sqft" or whatever. How do I enter that after my formula in my database header to show up 500 sqft. Thanks Matt Quote Link to comment
Tobias Posted September 30, 2010 Share Posted September 30, 2010 In edit worksheet mode Format cells... > Number Tab> Trailer and/or leader Quote Link to comment
Pat Stanford Posted September 30, 2010 Share Posted September 30, 2010 Select the header cell for the column and then the little black triangle pull down menu at the upper left of the worksheet. Choose Format Cells. On the Number tab set the type to Dimension Area. This will use the default area unit for the drawing. If you need a different unit, try the Leader or Trailer Fields on the same tab. Quote Link to comment
