Hello Community! Our community board will be offline for maintenance as we perform an upgrade from June 8th at 8:30 am ET until June 9th. We appreciate your patience and understanding during this time.
Wall end caps 2011
This is a bug.
When you go to 2D/Plan view, and you make the end caps again, then go to 3D view, you will see that when you select the wall, the end cap selection is correct of height, except it doesn't follow the wall slope. But the actual cap is at the base height of the wall, so i really think it's a bug.
It also seems that end caps are just the same as wall add-ons like we had in vw2010. So they doesn't behave correct!
NV: Please work out the components like real components that can be adjusted in every way independed of the overal wall!
