Dave Donley
RW 2011 Tip: Plain white exterior renderings
For plain white, softly-lit exterior rendering:
1. Delete or turn off all light objects.
2. Open View->Lighting->Set Lighting Options... dialog.
3. Set Indirect Lighting to Exterior, 1 Bounce
4. Turn off ambient
5. Click OK
6. Apply RW background "HDRI White" (from VW default library) to layer
7. Open View->Rendering->Custom Renderworks Options dialog
9. Turn off Textures
10. Turn off Colors
11. Set Anti-aliasing and Quality levels to taste
12. Render in Custom RW
HTH!
bear with me I do not do allot of rendering, but could you produce those buildings with full color landscape? I mean white buildings with a full landscape plan in color?
I tried this, but whats with the blotchiness? As far as I can tell i've got all settings set at the highest quality.....
Hello Vincent:
That is bizarre. Can you send me the VWX file?
Sure....
......I just tried with a clean new file and everything works great....so there is something wrong with this particular file and I guess as always something to do with the dwg(vwx) that is referenced into it.......( I also copied a couple of contour lines from the referenced file to create a terrain model with!)
I'll just have to copy all native VW objects to a new file and go from there I guess.....
Edited by Vincent C
Thanks for looking anyway Dave, I'll post again when I've set up the new file, and let you know how it went.
Edited by Vincent C
Well it was definitely a corrupt file.... dwgs really are terrible for VWs......
Edited by Vincent C
Yes you could.
Are you sure Peter?
Dave's method is to take the colour away in the rendering mode.
How could you get this to produce a white building in a full colour landscape?
Stacked Viewports?
Aligned layers with Unified View turned off?
haven't had time to try
Well a solution would be to give the buildings a solid white color.......... :) (then again how often is that the case......in a project)
Vincent,
White buildings would be nice from time to time when all I am trying to display is a color landscape and (white)building placement as a backdrop.
Propstuff is right in questioning the removal of color, I would like to know if it can be done as I am wondering how?
Just askin?
Everything that has a fill color of white will show as white everything that is given a color or texture will show as such, all you have to do is not do points 8 and 9 in the first post of this thread ie. keep Color and Texture checked in the View->Rendering->Custom Renderworks Options dialog
You can do it with class overrides, but only if the white buildings don't have a texture already applied to them and they are set to a by class fill.
The trees are really nice.
Please let me know what the settings are.
