John Windswept Design Posted September 14, 2010 Share Posted September 14, 2010 I have an elevation view port. Rendered with high quality back round and sketch for ground. Looks good on screen but when I print I only get the border. The page set up looks good. It seems like a bug. Any ideas? john t Quote Link to comment
John Windswept Design Posted September 15, 2010 Author Share Posted September 15, 2010 I can attach the file...... How do I attach a file again? Quote Link to comment
Kevin McAllister Posted September 15, 2010 Share Posted September 15, 2010 Have you tried outputting it as a PDF first and then printing the PDF? (Export PDF is your best option if you are running a design series version of Vectorworks, but Print>Save PDF will also work). To attach at file you need to select full screen Reply instead of Quick Reply. Kevin Quote Link to comment
John Windswept Design Posted September 16, 2010 Author Share Posted September 16, 2010 that is how I am printing. the file is too big. Quote Link to comment
Kevin McAllister Posted September 16, 2010 Share Posted September 16, 2010 I have had this happen before. My understanding was it was a memory issue. As an experiment, I would try reducing the sheet layer resolution and see if it works then. I remember deleting an rebuilding my viewport to fix it when it happened to me. Kevin Quote Link to comment
joerg Posted September 17, 2010 Share Posted September 17, 2010 that rings an old bell.... may be its a corupted font it has happend before! http://techboard.nemetschek.net/ubbthreads.php?ubb=showflat&Main=28070&Number=137179#Post137179 Quote Link to comment
