7ana Posted September 12, 2010 Share Posted September 12, 2010 I have the 2009 Student Vectorworks version, and need to import a DWG file ASAP, but when I try an error message appears: "OpenDWG Library Error 8: This DWG file is not supported" I think it's a 2007 DWG file, how can I fix it in order for it to import? Quote Link to comment
0 Vincent C Posted September 12, 2010 Share Posted September 12, 2010 post it here and I can save it as an earlier version...... Quote Link to comment
0 7ana Posted September 12, 2010 Author Share Posted September 12, 2010 I attached the DWG to my earlier post, thank you for your help! Quote Link to comment
0 Vincent C Posted September 12, 2010 Share Posted September 12, 2010 Is the dwg in inches or mm? Quote Link to comment
0 7ana Posted September 12, 2010 Author Share Posted September 12, 2010 I'm not sure, it should be inches Quote Link to comment
0 Vincent C Posted September 12, 2010 Share Posted September 12, 2010 (edited) Sorry it took a while, File Manager doesn't work....here's another way.... http://dl.dropbox.com/u/8381286/Dwg%20VW12.mcd I saved it as a VW12 (there was no option for 2007)......just saw you had 2009! It must be time to go to bed :sleep: ...... Edited September 12, 2010 by Vincent C Quote Link to comment
0 7ana Posted September 12, 2010 Author Share Posted September 12, 2010 Thank you so much! You're a life saver, VW12 is ok, when opened with my Vectorworks it converts into 2009, so thank you again. Quote Link to comment
0 Vincent C Posted September 12, 2010 Share Posted September 12, 2010 No problem.... Quote Link to comment
7ana
7 answers to this question
