ar.himanshu Posted September 12, 2010 Share Posted September 12, 2010 (edited) is it possible to explode symbol in VW 2010 as it is done in AutoCAD blocks? Edited September 12, 2010 by ar.himanshu Quote Link to comment
starling75 Posted September 12, 2010 Share Posted September 12, 2010 Convert symbol to group and then ungroup: Modify / Convert / Convert to group Modify / Ungroup Quote Link to comment
ar.himanshu Posted September 12, 2010 Author Share Posted September 12, 2010 it doesn't work, if i convert symbol to group..... the symbol remains the same I want all object entity different as it was before making symbol Quote Link to comment
Benson Shaw Posted September 12, 2010 Share Posted September 12, 2010 Should work. 1st step has to use the Modify/Convert/Convert to Group (Cmd K is the key shortcut). The standard Modify/Group command (Cmd G) does not work for this. If there are nested symbols or groups, a dialog box appears. Choose the bottom one for Convert All. Then Ungroup (Cmd U) repeatedly until object count in OIP does not change. Some people use the word "explode" to mean reducing all objects to primitives, for example reducing a rectangle to 4 straight line segments. The command for this in VW is Modify/Decompose. Post a VW file with the symbol if this does not work for you. Please make yourself a profile with a signature in this forum's My Stuff tab near top of the forum window. Show your VW version and a bit about your OS and hardware. That helps with troubleshooting. -B Quote Link to comment
Miguel Barrera Posted September 13, 2010 Share Posted September 13, 2010 One of the hardest things for new VW users is to leave behind their Autocad habits which leads them to try to emulate exactly how they used that program. So I wonder, why do you need to "explode" a symbol? If I needed to create a variation of an existing symbol, I would duplicate, rename, and then edit it in the symbol editor workspace. Quote Link to comment
ItsALLrigged Posted February 15, 2012 Share Posted February 15, 2012 How do I "rename" in this process? Thanks, Quote Link to comment
ItsALLrigged Posted February 15, 2012 Share Posted February 15, 2012 Self answered. Quote Link to comment
