Wishes for vw 2012
Jershaun
1. 3D Hatches
2. Clash Detection
3. True Multi Core Support (Use all cores 100% to execute tasks)
4. Full 64-bit Support
5. Window tool improvement (Current Window Sill makes Window Tool Irrellevant)
6. True Hardware support (Currently hardware accelerated panning and zooming/navigation doesn't work)
7. Proper solution to working in a team (current workgroup referencing is inadequate. Similar to archicad's teamwork would be good)
8. Ability to place window/opening half-way between floors without having to reshape walls and come out with work arounds for viewing same on plans eg. a stairwell
9. Shadow Catcher
10. Line styles to objects in Unified view and also to 3D objects (eg. 3D Polygon)
11. Interactive Section Line/cutting plane.
12. Automatic representation of objects on other layers relative to a chosen layer (eg. layer above like a roof, to be dotted)
13. More interactive type of modeling similar to SolidWorks and SpaceClaim.
14. Wireframe and OpenGL speed increase, including switching between them.
15. Current PIO system to be scrapped and an alternative and more interactive method to be incorporated.
16. Proper working and fully thought out stair tool.
1 answer to this question
1- PIO visibility options: stairs, windows, doors etc. must be able to be visible on more than 1 story (DL) with different 2D symbols.
2- PIO visibilty options: windows, doors etc. must be able to have different attribute settings in plans, sections/elevations.
3- Leaning Walls
4- Oval/Elliptical walls
5- Overall stability!!!
6- Multi core 64 Bit support
7- Archicad import/export
8- Chain dimension import/export DWG
9- DLVP of a DL in itself.
10- DLVP of live sections/elevations
11- direct DLVP/SLVP of external DWGs etc. (no import first)
12- Better compatibility between versions.
13- Workspace selection at startup
14- Multiscreen capability
15- Make walls etc snappable for extend/trim lines etc.
16- Elevation/Section 2D symbol (like (Top/Plan) for hybrid symbols.
17- OIP>Render>Part> add an option for reverting all parts to overall.....
18- Associative hatches in Section/elevation viewport annotation
Edited by Vincent C
