Craig Jennings Posted September 1, 2010 Share Posted September 1, 2010 Can anyone tell me how (if) I can "cut" the ends off of a sweep object. I am trying to model sections of spiral HVAC ducting. I can create a sweep that looks pretty good, but I need to "cut" the ends off square to get the length just right and so I don't have the "tails" on both ends. I sense that I probably have to convert the object from a sweep to something else before I can do that. Quote Link to comment
Craig Jennings Posted September 2, 2010 Author Share Posted September 2, 2010 Nevermind. I found the answer in an earlier post. It was an overlap problem. Quote Link to comment
mike m oz Posted September 2, 2010 Share Posted September 2, 2010 Use the Split tool in Line Split or Line Trim mode you can trim the ends off. If you step back through the two edits using Edit Group the original object will be there. Quote Link to comment
