One area where Vectorworks could improve on is in it's consistency. Here are a couple of examples that will hopefully illustrate this point.
Example 1: In Vectorworks 2010 there are two stair object tools. This can be confusing, especially for new and or occasional users when trying to select the best/correct tool for the job. There should only be one stair tool.
Example 2: Wall objects are another example of inconsistent behavior. There are four wall object types in Vectorworks 2010 which are fairly straight forward in their respective use cases, however the behavior between them isn't consistent. For instance, you can insert door objects into standard wall objects, but not window wall objects. This is very frustrating! Once more, this design seems to be limited in it's scalability. Will a new wall object type be created for leaning, oval, or elliptical walls? Why not have one wall object tool? Instead of having a separate window wall, just use the standard wall object, then select a ?window wall? or ?curved window? wall style.
Linicks
All,
Thanks for considering this suggestion!
2 answers to this question
