Ted W Posted August 25, 2010 Share Posted August 25, 2010 I can see from other posts that people do have problems with the call-out tool. Mine is a little different. In some, but not all drawings, I get an error message when I attempt to label with the callout tool; An attempt to define a Plug-in Object named "Callout" failed because Symbol Definition with that name already exists in the current document. The entire operation is cancel Any suggestions welcome. Thanks Quote Link to comment
mike m oz Posted August 25, 2010 Share Posted August 25, 2010 Anything with the same name as a PIO will result in a message like this. It might be a symbol, a hatch etc. or even a Layer or Class name. Rename the offender and the Callout tool will work again. Quote Link to comment
Ted W Posted August 26, 2010 Author Share Posted August 26, 2010 Many thanks. Could not locate any PIO labelled "callout" but by selecting and pasting the drawing as a new file I sorted out the problem. TW Quote Link to comment
Jeffrey W Ouellette Posted August 27, 2010 Share Posted August 27, 2010 Ted, The Callout tool is in the Basic palette. Quote Link to comment
Ted W Posted August 27, 2010 Author Share Posted August 27, 2010 Jeffrey, Thanks but problem arises when I use the Callout tool. If I understand Mike correctly the error message is telling me that the word 'callout' is somewhere in that drawing file so I need to rename it, but I cannot find anything with that name. The problem may be because I exported the file as a dwg, emailed it to a ACAD colleague who emailed it back (as a dwg) with some work added. It was then that the problem arose. Even by deleting all of the classes (except none and dimension) the callout tool would still not work! TW Quote Link to comment
Kevin McAllister Posted August 27, 2010 Share Posted August 27, 2010 Ted, If you delete most of the items out of a test file, the conflict is most likely in a symbol. When you do the round trip from Vectorworks to Autocad and back, many things come back in a symbols often nested in other symbols. I suspect you'll probably find your conflict somewhere in the Resource Browser items. Kevin Quote Link to comment
Ted W Posted August 28, 2010 Author Share Posted August 28, 2010 Kevin, Exactly right, many thanks. I discovered that all the ACAD labels were labelled 'Callout 1',2,3..... Once deleted or renamed the problem was solved. Thanks again Ted Quote Link to comment
Kevin McAllister Posted August 28, 2010 Share Posted August 28, 2010 Glad to hear I was able to help. Cheers, Kevin Quote Link to comment
