billtheia Posted August 19, 2010 Share Posted August 19, 2010 Is it possible to make a z-shaped stair using the "new" stair tool (NOT custom stair tool) in VW2010? See attached pic. Quote Link to comment
CipesDesign Posted August 20, 2010 Share Posted August 20, 2010 Yes I'm sure it's possible. But I don't have the time right now to experiment. Just keep adding "flights" and "landings" until you get what you want. Hint: try using negative numbers for the landing angles if positive numbers don't work. Let us know! Quote Link to comment
billtheia Posted August 20, 2010 Author Share Posted August 20, 2010 That's just the thing, Peter, the new stair tool doesn't seem to allow adding landings and flights like the old stair tool (now custom stair tool) did. It looks like I can only have straight, L, U, circular, and winder. I've considered trying to make it out of several separate stairs but I can't seem to get a stair that starts or ends with a landing. Am I missing something about the new stair tool? Quote Link to comment
Jonathan Pickup Posted August 20, 2010 Share Posted August 20, 2010 Peter, this stair is NOT able to be made using the new stair tool in Vectorworks 2010, but it is possible if you use the custom stair. Quote Link to comment
CipesDesign Posted August 20, 2010 Share Posted August 20, 2010 Right. I have discovered that (having been reminded by various folks). It's too bad that this capability does not exist. But then again, we do have the older stair tool if needed. Hard to imagine the range of complexities needed in these tools. I wish we (eventually) could have just one that contained all... Oh well... Sorry for the mislead. Quote Link to comment
CipesDesign Posted August 20, 2010 Share Posted August 20, 2010 Bill, if you're willing you might try using a combination of Floors and Stairs. Of course the railings will be tedious. But it might be worth a shot. Quote Link to comment
billtheia Posted August 20, 2010 Author Share Posted August 20, 2010 As I thought - can't do it with the new stair tool. I did model it with the old (custom) stair tool but it leaves a bit to be desired. The object, itself, is slow (takes time to regen when you move it,) the handrail is buggy, and the PIO seems to crash VW from time to time. We really DO need a single, comprehensive stair tool that is quick and stable. I'm beginning to worry that we won't ever get one, though. Requests for a improvements to the stair tool date back to when Moses was a kid. I've been using VW since VW2008 and am now using VW2010. The stair (now custom stair) tool has only changed in minor ways in the last three versions of VW. It's still just as buggy and broken as it was in 2008 (and I suspect before that.) I was encouraged when I heard that VW2010 would have a new stair tool. I was hoping for quite a bit more than we actually got. Instead of fixing the existing stair tool (which has several useful features - including the ability to link to layers and their heights,) NNA bought a third-party PIO and stuck it in the old stair tool's place. Each of the tools has it's strengths but each also has serious weaknesses. We need ONE tool that works well. NNA, Please. Quote Link to comment
