Simon Carus-Wilson Posted August 16, 2010 Share Posted August 16, 2010 Hello All. Having made a new LL I am unable to edit it. I go back in to the LL manager make the changes, exit, hit refresh Labels or refresh instruments with instrument selected and am not getting the desired effect. Heres what I am getting. Field moves once very slightly and then does not move again. I seem to be able to turn field vertical. I have tried deleting and recreating a new LL. If I open up a new file and use the same instrument and create a new LL it works fine. If I copy the Layer and paste it into a new file everything works fine. I would be happy to copy everything over but I'm having issues with getting all the layers to line up as well as scale issues. Are there any preference files hidden away somewhere ? Or if anyone could give me some pointers on copying everything over into a new file I would be most grateful. This Drawing was created in 2010 and Exported to 2008. Thanks' all. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted August 16, 2010 Vectorworks, Inc Employee Share Posted August 16, 2010 Use the Assign Legend To Insts command to reassign the Label Legend to the instrument. Quote Link to comment
Simon Carus-Wilson Posted August 16, 2010 Author Share Posted August 16, 2010 Hello Kevin. Yes I have used the Assign Legend To Insts command. I did delete the LL from the lamp and then reassign the LL, same result. Would you like me to send you the file so you can interrogate it ? Quote Link to comment
Simon Carus-Wilson Posted August 16, 2010 Author Share Posted August 16, 2010 So after editing the LL you reassign the LL to the lamp even though it already has the LL assigned to it and it works. I've never come across that but all is good now. Thanks' for the quick reply Kevin. Quote Link to comment
