Heath
VectorBits VB XY
I am trying to use the Vectorbits VB XY plug-in to obviously give me the x,y coordinates. When I place it on my drawing the coordinates are not correct. They do not match the x,y shown in the object info. pallette. What is this plug-in using for a 0,0 origin? Any ideas?
Thanks,
Heath
If you double-click on the 'VB XY' tool it pulls up the 'Create Object' config settings, and there at the bottom you can set the X & Y origins back to 0,0 or whatever you want.
You can also change the origin for an already created XY object from the OIP.
HTH,
Tim
Thanks Tim, but the origin is set to 0,0 in the Create Object pallette. When I place the VB XY on a locus I have at 0,0 the displayed data is: X:-394.856536
y:-528.301886. It has been quite a while since I have used this tool. I think it was VW2008 when I last used it without this issue then upraded to VW2010.
It works fine for me in a new document in 2010, so I don't know what you are experiencing. I'd try it in a new, blank document and see if it's any different.
Regards,
Tim
