Export image file: boundaries
Is there any particular reason why the perspective view outline was used as the basis on which VW exports images? If you happen to be in the wrong layer, VW's export may not function, unless the outline is set the same for all layers.
Second, of what function is the 'resolution' field if you're specifying how many pixels you want in the output image?
Last, though it will be sent to bugsubmit, you can get around a maximum width or height of 15 000 pixels if you set the lesser dimension to a higher value, up to 15 000. e.g.: my pic is 21600x14400. Entering 21600 for width gets reset to 15000, height results in 8900. Entering the 14400 as a height will result in a width of 21600. I haven't actually counted all the pixels to make sure the greater-than-15000 value carried through tongue.gif" border="0 but I'm assuming it worked.
