jhubbell Posted December 16, 2001 Share Posted December 16, 2001 How do you unlink layers Quote Link to comment
MikeB Posted December 16, 2001 Share Posted December 16, 2001 Select the layer link.Go to the Edit MenuSelect UnlockHit Delete Good Luck Quote Link to comment
FRED JOHNSON Posted December 16, 2001 Share Posted December 16, 2001 Not to be dense, but I have never quite understood this either... what is "select layer link"? exactly or specifically WHAT is being selected? fjjRA Quote Link to comment
MikeB Posted December 16, 2001 Share Posted December 16, 2001 Best I can describe it a layer link is like a shadow. It has the size and shape of the origional layer and will change with the origional layer but it is not an editable object. You can move the layer link around but you cannot edit anything included in the link, you have to edit the source layer. So the link itself is only a representation of the information being linked. I don't know if that helps or makes sense, but I've found layer links incredibly useful, particularly in 3-D modeling. Good Luck Quote Link to comment
TiTaNiuM sAMuRai Posted December 16, 2001 Share Posted December 16, 2001 You might also think of layer linking as a tool with some of the 'Class x on/off", 'Layer x on/off' features of a saved sheet, but you're not forced to revert to any particular view of the objects you want to see. Quote Link to comment
CipesDesign Posted December 17, 2001 Share Posted December 17, 2001 A layer link is an object made up of other objects. For example, if you have a layer for your main level plan and a layer for your upper level plan, you can link the two in a third layer. The object that is generated is the "link". Careful when ungrouping and changing stuff in a link, those changes will not occur in the original layers. I usually like to go into the original layers to make changes, which WILL be reflected in the linked layer. Hope this helps. PLC Quote Link to comment
