Nathan_B Posted July 17, 2010 Share Posted July 17, 2010 I'm making my first foray into Vectorworks worksheets and custom formulas. I would like my window schedule to tell me the orientation of each window (North, South, East, West) so that I can calculate the total area of glazing on each facade. Any suggestions as to how I can make this work? Quote Link to comment
islandmon Posted July 19, 2010 Share Posted July 19, 2010 Try creating a New Record and attaching it to the Windows. Then you can assign one of the 4 fields (North, South, East, West) to each instance. The worksheet would reference the Record and list the Field. Quote Link to comment
Guest Wes Gardner Posted July 19, 2010 Share Posted July 19, 2010 There's also a field called Location in the Data pane of the Window Settings dialog box - this can then be used in a column in your window schedule. =('Window'.'Location') Quote Link to comment
Ian M. Posted November 1, 2023 Share Posted November 1, 2023 On 7/19/2010 at 9:23 AM, Guest Wes Gardner said: There's also a field called Location in the Data pane of the Window Settings dialog box - this can then be used in a column in your window schedule. =('Window'.'Location') Dare I bring up a comment from 13 years ago? I would like my window schedule to show the orientation of each window for energy calculation purposes. It seems that Vectorworks would know the exact angle the window faces, but how would I extract that information? I found the field called 'Location' under the 'Data' category in the Window Settings pane, but I don't see how or where to either input location information, or see what data it uses? Would 'Location' include the orientation of the object? %22Location'.pdf Quote Link to comment
