robk Posted July 9, 2010 Share Posted July 9, 2010 (edited) I have imported a pdf of a hotel meeting room floor plan and layed out my seating etc. Now when I go to different views the pdf stays in the Top/Plan view while everything else changes to the selected view. Is there any way to make the PDF also change views? Obviously I don't expect it to be 3d but I thought it would at least "angle" its self to the correct perspective. Rob Edited July 9, 2010 by robk Quote Link to comment
Pat Stanford Posted July 9, 2010 Share Posted July 9, 2010 Select the PDF and set it to be a Layer Plane Object in the Object Info Palette (OIP). Set the 3D view and then Render and you should be able to see the PDF "Laying on the floor" In wireframe all you will get is the border of the PDF. Quote Link to comment
robk Posted July 9, 2010 Author Share Posted July 9, 2010 Even when rendered I am just getting the border of the PDF. HMMMMMMMM? Quote Link to comment
michaelk Posted July 9, 2010 Share Posted July 9, 2010 Select the pdf. Modify>Ungroup Accept the dire warning. In place of the pdf will be three objects: ...1 a bitmap - throw it away ...2 a rectangle - throw it away ...3 a bunch of lines. Select all of them and in the OIP set the Plane to Layer Plane. That should work in any view. Quote Link to comment
robk Posted July 9, 2010 Author Share Posted July 9, 2010 For some reason when I ungroup all the walls and such are contained in that bitmap so when I delete it they all go away....I may just have to stop being lazy and trace it, I was hoping I wouldn't have too. Rob Quote Link to comment
michaelk Posted July 9, 2010 Share Posted July 9, 2010 Is the pdf made from a vector based application, or is it a scan of a hand drawing? If it's a scan or any other raster based drawing, then the above steps don't work. If it is a vector based pdf, make sure you look under everything for the lines. Keep deleting until you get to the lines. Quote Link to comment
robk Posted July 9, 2010 Author Share Posted July 9, 2010 I don't think its vector based, it's just a PDF the hotel sent me. Quote Link to comment
Pat Stanford Posted July 10, 2010 Share Posted July 10, 2010 If it is vector based, you don't have to do the ungroup. As a Layer Plane object the PDF will display just fine. Try it and see Michael. From the hotel, it was probably done in photoshop or scanned in so you will have trace it if you need the information. VW can only help so far. If you have Illustrator, see about importing the PDF and exporting as a DXF/DWG from there. See this thread: http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=142615&Searchpage=1&Main=29209&Words=illustrator&Search=true#Post142615 Quote Link to comment
michaelk Posted July 10, 2010 Share Posted July 10, 2010 Pat Should have read your post more carefully. You're correct, it works - except for wireframe modes. Which disables nudging. So I've just fallen into the habit of disassembling pdfs automatically when I want to work w/ them in 3D. Great tip about using Illustrator. Quote Link to comment
