RichieHatch
rotating 2d views?
hi
can you rotate a 2d view to work orthogonally to a plane at for example 3 degrees in 8.5.2.. when working on some projects there may be an entire block of a building rotated at an angle. I know that you can set an angle in your snaps but is there another way. I used to use Microstation and was able to rotate a view by clicking on a rotated element and i think that you can do it in autocad also. if you cant do it in 8.5.2 can you do it in 9 or 9.5.
